HONDA FORUM AND NETWORK
Honda plate frames
 **REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PARTOUTFirst  1 2 >  Last
rolando_211
4 posts [100%]
san diego ca
6-22-2016
  *Updated Prices and Parta List!! REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PART OUT« » Reply  Edit
I hate to do this but I need to part ways with my project. Majority of the parts are BRAND NEW unless stated otherwise. With that being said, prices are pretty much firm. I am located in San Diego, CA. Shipping is available but the fees and cost will be handled from the buyer. Here are a few pictures of how the car will look like near its finished form. If you want to see pictures asap my IG is @rolando_211 to see the progress of the build. Please no rude remarks as I have no time for that. If you don't agree on the price, just simply hit the backspace. My car was built for the intentions of road racing hence all the parts that support that type of activity. Best way to reach me is at rolandotoledo01@yahoo.com or feel free to contact me at my mobile number 8589997421. Thank you for your time and thanks for looking. Now onto the parts list..
SHELL $6500
1993 EG4 VTi. REAL RHD FROM JAPAN REGISTERED in California under the 10 digit identification number as a CLEAN TITLE. BLUE TAGGED. Pink slip under my name.
K series ready
The whole chassis has been stitch welded every inch to reinforce the body
Interior has been resprayed along with the wheel wells with atextured coating
Engine bay has been shaved and painted as well
Exterior paint is 9/10 as there are a few paint chips
Authentic Spoon duckbill
OEM window visors
Hardrace front lower control arm bushings
Hardrace compliance bushings
98 spec ITR suspension
Integra brakes all around
S2k clutch master w/spacer
Oem front lip
Spoon style front spoiler (beater lip)
Thin side moldings
JIC magic rear tie bar
ARP extended studs
Karcepts KWHO2 36mm hubs
43mm ID OEM NEW wheel bearings
PCI spherical rear camber kit
Front and rear mud flaps
Subframe powder coated black
Steering rack power coated black
Hasport black anodized 70a EGK1 mounts
Wheels are sold so will come with steelies
ENGINE $5000 obo SOLD
k24a2 2007 Cylinder head
Skunk2 stage 3 camshafts
Skunk2 springs
Skunk2 retainers
New OEM head gasket
RRC intake manifold
Cut
K Tuned MAP plug
1000cc Injector Dynamics injectors
k24a8 block
87.5 12.5:1 Wiseco pistons
Eagle rods
Block guard
RSX type s oil pump
RSX type s aluminum oil pan
ARP headstuds
New OEM chain
K tuned timing chain tensioner
Circuit Hero timing chain guide
Karcepts power steering ac delete
Type r transmission (Y2M3)
2nd-3rd carbon synchs from Synchrotech
Lightweight flywheel (unsure of exact weight)
Action Clutch stage4 4 puck clutch (0 miles)
Will come with 99% of all sensors needed
PARTS
K Tuned swivel neck housing; $130
K Tuned intake manifold adapter; $90
K Tuned straight slip on hose upper coolant housing with filler neck; $130
K Tuned 80mm TB; $350
K Tuned center feed fuel rail; $140 SOLD
K Tuned fuel filter tuck; $220
K Tuned fuel pressure regulator w/ gauge; $160 SOLD
K Tuned traction bar (used); $250
K Tuned shifter plate; $110 SOLD
K Tuned billet shifter; $375 SOLD
Rywire Tucked K Version 2 engine harness ; $650 SOLD
All in Fabrication tucked radiator w/ Blu high performance dual fans (radiator used, has been pressure tested. Fans brand new) $450
Function 7 rear LCA spherical (type r style); $270
PLM megaphone header; $500 SOLD
Walbro 450 LPH E85 pump (used); $120 SOLD
Vision TC Mirrors with eg bases $700 SOLD
PCI version 2 spherical front camber kit $140 SOLD
PCI version 2 spherical rear trailing arm bushing $150 SOLD
<br /><br />
Modified by rolando_211 at 2:24 PM 8/3/2016
Modified by rolando_211 at 11:57 AM 9/19/2016
crazy4hp
1476 posts [100%]
NC
8-12-2008
Quality build.. Sucks you couldn't finish it.. Glws
Official_s2k
15 posts [100%]
Bayshore NY
12-5-2014
 « Re: **REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PARTOUT (rolando_211)« » Reply  Edit
Can you post up contact info thanks
cetcivic
297 posts [100%]
brooklyn ny
1-16-2009
 « Re: **REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PARTOUT (Official_s2k)« » Reply  Edit
Glws
et626
139 posts [100%]
baldwin park ca
6-1-2010
Bump
RACE IN PARADISE JUANITO WE MISS YOU
rolando_211
4 posts [100%]
san diego ca
6-22-2016
 « Re: (crazy4hp)« » Reply  Edit
Thank you
kid6061
740 posts [100%]
Santa Clarita CA
11-29-2009
Bump for Rolando and a clean shell 👍👍
No rest for the wicked, money doesn't grow on trees....NOW LISTEN TO DIS TRACK BITCH!
ClutchFoot
16 posts [100%]
Sur Califas CA
8-21-2016
 « Re: **REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PARTOUT (kid6061)« » Reply  Edit
Bump for a whole lot of freshness GLWS
NotBryce
87 posts [100%]
Sav Ga
7-23-2013
 « Re: **REAL RHD EG4 VTi CALIFORNIA REGISTERED K SERIES PARTOUT (ClutchFoot)« » Reply  Edit
$8000 for a shell? Enjoy your "investment"
rolando_211
4 posts [100%]
san diego ca
6-22-2016
UPDATED PRICES AND PARTS LIST
Kidhuf
8 posts [100%]
Toronto Ontario
2-24-2013
Do you have the power door panels I'd be interested in those
rolando_211
4 posts [100%]
san diego ca
6-22-2016
 « Re: (Kidhuf)« » Reply  Edit
I dont. The shell didnt Have door panels and I never got around to buying some. M's JDM had a set with switches. I believe it was brown tweed fabric, grey panels.
 First  1 2 >  Last
» Return to Automotive Classifieds
