HONDA FORUM AND NETWORK
Honda plate frames
 **skip's Milano red DC4 build - 2017 comeback**First  1 2 3 4 5 6 7 >  Last
skip
Spoon me please
4812 posts [100%]
Rainy WA
12-10-2008
  **skip's Milano red dc4 build - 2017 comeback**« » Reply  Edit
Contents:
Page 1:
- Refresh
- Bay spray
- Rywire clutch line/vtec sub harness
- Undercoated wheel wells
- OEM engine harness plug/hole
- Odyssey battery installed on custom mount
- s2000 clutch master installed
- Block cleaned
- Brake line mock up
- MFactory shifter bushings
- Euro Integra clear signals
Page 2:
- New brake lines
- New lines bent and fitted
- OEM CTR N1 crank pulley/belt
- 08 Spoon Sports catalog
- Brake lines painted
- Booster painted
- Rear lines mocked up
Page 3:
- Installed items in the bay:
- Booster/master cylinder
- OEM ek harness plug
- heater control switch
- NEW front brake lines
- Block disassembled
- PR3 pistons
- Front undercoating finished
- Coated some parts in semigloss black
- Front lower section
- Front tow hooks
- Front brake lines installed
Page 4:
- Spoon Duracon knob
- B16 dual valve springs
- Misc. OEM grommets pluts etc..
- OEM PR3 piston rings
- Custom 3' ASC Intake pipe
- Canibeat plate frame/lanyard
- Front brake lines done!
- OEM ITR throttle cable installed
- Rywire soft clutch line installed
- OEM hood prop hardware installed
Page 5:
- ACL race bearing kit/thrust washers
- ARP head/rod bolts
- Engine back from machine
- Spoon oil cap
- Spoon rad cap
- 2x Spoon black rad stays
- Polished gsr crank
Page 6:
- Spoon socks
- Supertech valve stem seals
- Techflex harness loom and shrink
- Longblock mock up
- VC stripped
- ARP rod bolts and rods off to machine
- Head off to assembly
Page 7:
- Nylon black hole plugs for bay
- Engine assembly supplies
- Summit order delivered
- Painted fpr
- Fuel rail mocked up
Page 8:
- Front brakes refreshed
- Front subframe cleaned and reassembled
- Earl's PS loop
- Fuel hardline converted to softline
- New filter and lines installed
Page 9:
- Moroso baffled oil pan
- VC prepped/painted
Page 10:
- VC complete
- OEM ITR checkered trunk mat
Page 11:
- OEM ITR checkered mats
- Wheel wells stripped
- POR15 w/ brushes
- SEM trim paint
- OEM exhaust mani refreshed
- Head partially reassembled
- ARP 9mm rod bolts installed
Page 12:
- Front/rear wells stripped
- OEM ITR arm rest w/ badge
- Exedy stage 1 clutch
- Competition 11lb flywheel
Page 13:
- Top/bottom end gasket kit
- TB/water pump/tensioner/spring
- Thermostat
- Oil pump
- F7 lca
- ASR subframe brace
- Honda Access ITR pedal covers
Page 14:
- Tai (Merkone's) interior shot
- No updates
Page 15:
- Bum update
Page 16:
- ASC front/rear strut bar
- Ohlin's engine damper
- Rear ASC strut bar w/trim installed
Page 17:
- Energy rear trailing bushings
- PIC stiffened bushing kit
- Innovative billet B street mounts
Page 18:
- POR15 coated in wells
- OEM AC delete duct
Page 19:
- Front hubs and rear arms refreshed
Page 20:
- Enkei NT03's
Page 21:
- ITR rear seat
- Rear ITR trunk mat installed
Page 22:
- Short block assembled
Page 23:
- LHT master cylinder brace
- Rotors resurfaced
Page 24:
- Head parts cleaned
- New head gasket installed
- Head w/ valvetrain installed
- New oil pump installed
- Rear main seal installed
- Oil pump/tray installed
- Moroso pan installed
- New water pump installed
- CTR N1 crank pulley and TB tensioner installed
- Alternator cleaned and installed
- H20 jacket recoated and installed w/ new thermostat
- Spoon Ventuli IM plate w/ gasket installed
Page 25:
- Cusco E-brake button
- Small Spoon collection
- Moroso baffles for Hubes
Page 26:
- Bolt Boys B engine bolt kit
- Me and the GF
Page 27:
- No updates
Page 28:
- Spoon gen 1 DC tow hook
- New package
Page 29:
- New part
- Spoon preview
Page 30:
- Spoon dc cluster
Page 31:
- cams installed
- longblock almost complete
- subframe installed
- Spoon tow hook installed
- Spoon pile
Page 32:
- Interior pieces powder coated
- Nardi Deep Corn 350
- Horn "collection"
- New Spoon duracon
- Engine harness headache
Page 33:
- Spoon crane etched
- Bezel complete
Page 34:
- Cluster complete
Page 35:
- No updates
Page 36:
- New grounds
- New pedal hardware
- Pedals finished up
- Nardi wheel w/ Spoon horn
Page 37:
- Energy trail/arm bushings
- Russell brake lines
- Pedals installed
- Brake rotor faces painted
Page 38:
- Spoon rail pic
Page 39:
- Small Honda order
- Throwbwack shot
Page 40:
- Spoon ITR Intake
- New engine bay hardware
- MC brace modified
- E-brake button modified
Page 41:
- New lower front ball joints
Page 42:
- USDM ITR seats
- JDM ITR Recaro SRDs
- Dropped some stuff at powder coat
Page 43:
- No updates
Page 44:
- Blox camber kit
- New Honda brake pads
- SixSigmaRacing side sweep B series race header
- Car as it sits
Page 45:
- More header pics
Page 46:
- No updates
Page 47:
- Front ball joints pressed
- Rear trailing arm bushings started
- New Recaro seat rails
- Interior comin back together
Page 48:
- Cluster and Nardi mocked up
- Funny pic from Jbayy
- Bay shot
- Russell brake lines up
- Headlight harness finished up
- Engine off stand
- Competition flywheel installed
- Exedy clutch installed
Page 49:
- New package
- Gen 3 Spoon N1
- Engine cleaned up a little
- Bolt Boys kit installed
- Fuel line from rail complete
- ASR brace installed
- F7 LCA's installed
Page 50:
- Little vacation
- Interior harness re-taped
- Dash mocked up
- Climate control installed
- Ring grommet for Spoon speedo
- Recaro clean up stage 1
Page 51:
- Recaros all finished up
- New throwout bearing installed
- Tranny mocked up
- Freshly blasted Vtec solenoid
- Si deck installed
- Seat rails mocked up
Page 52:
- Seat rail block plates
- Passenger seat installed
- Spoon cluster installed
- ITR mats tossed in
- Nardi wheel mocked up
- Batch back from powder coat
- LHT mc brace mocked up
- Spoon cluster lit up
Page 53:
- No updates
Page 54:
- Window cowling cleand and installed
- UCA arm mounts refreshed
- New UCA hardware
- Blox camber kit installed
- Front LCAs installed
- Front spindles installed
- Front sway bar cleaned and installed
- Energy RTA bushings installed
- Rear trailing arms installed
- Rotors installed
- NT03s tossed on for a peak
Page 55:
- No updates
Page 56:
- Front brakes/pads installed
- Rear brakes/pads installed
- Wheel mocked up
Page 57:
- No updates
Page 58:
- Harness work
- New front mud flaps
- New tires!
- Bridgestone Potenza re760 sport
Page 59:
- Engine all cleaned up
- Mocked up vc
- Header mocked up
- New packages
Page 60:
- Spoon car models
- Spoon OG dc mirrors
Page 61:
- OEM UK ITR clear bumper lights
- New tool box
- New air impact/ratchet set
- Black Rays duranuts
- JDM silver valve stem caps
- Front end pic
- Quick disconnect battery terminal connectors
Page 62:
- Wheels cleaned up
- Wheels/tires loaded up
- Wheels/tires mounted
- Koyorad cleaned up
- Spoon rad stays x2
- Koyorad installed
Page 63:
- 1998 Integra service manual
- Alt brackets refreshed/installed
- Clutch slave refreshed/installed
- Half shaft refreshed
- Wheel/tire mock up
Page 64:
- New axle seals
- Half shaft installed
- More harness work
- CTR cams
- Bumper cleaned
- New bay hardware
Page 65:
- Harness separated
- Harness starting to get loomed
- JDM ITR injectors
Page 66:
- UKDM signal clean up/repair
Page 67:
- Quick disconnect harness plug
Page 68:
- OEM B16 distributor
Page 69:
- Spoon horn button
Page 70:
- Wire harness progress
- OEM plug wire cover w/ signed TypeOne decal
Page 71:
- Distributor refreshed
- Injectors cleaned up
Page 72:
- Floating car pic
- ICB decal tossed on
- CTR cams polished
- AC block off project started
Page 73:
- Snowy day
- F7 ITR spec lcas
Page 74:
- Gunk brake fluid
- Newly bent lines
- Rad. reservoir mounted
- ITR F7's mounted up
- New package
Page 75:
- Spoon package
- ITR Rad hose set
- N1 silencer
- Thermo switch
- Magnetic drain set
- Small crane decal sheet
- JDM newspaper
Page 76:
- No updates
Page 77:
- New Starbucks logo
- Brake line close up
- More POR15 in wheel wells
- Distributor wiring cleaned up
- New OEM window cling from Sammy
- Custom battery stay
- Spoon pic
Page 78:
- New package
- C8Sport ITR spec coilovers
Page 79:
- Rubber sided washers
- Coilovers installed
- Car on the ground
Page 80:
- Car on the ground again
Page 81:
- Garage shot
- Engine hoist ready to go
- Masked off/primed/painted new brake lines
- New prop valve hardware
- Fuel filter mocked up
Page 82:
- Bay ready for a motor
- Honda gathering
- Motor ready to go in
- Cleaned up mount hardware
- Motor lined up
- Motor IN!
Page 83:
- SSR side sweep header installed
Page 84:
- Koyorad installed
- Front bumper tossed on
Page 85:
- Fuel line from rail to filter finished up
- Spoon thermo switch installed
- Pulled the car out for some sun
Page 86:
- More pics in the sun
Page 87:
- Trip to SpeedFactory
- Socketed P28 ecu
- New chip w/ base map
- BWR TPS sensor
- Blox rear camber kit
Page 88:
- Spoon hoses and intake down from the close
- Spoon hoses installed
- Rywire clutch line ran/installed
- Intake mocked up
Page 89:
- Spoon intake
- OEM CAI tube modified
- Intake installed
Page 90:
- Blox rear camber kit installed
- JDM ITR b pip
- Shorty test pipe
- AC block off grommet complete
- Random car shot
Page 91:
- Hood out of house
- Hood installed
- Bay shot
Page 92:
- New axles
- Spoon mirrors takin apart for paint
Page 93:
- Harness progress
- Close up shot
Page 94:
- JDM ITR mid pipe installed
- Spoon N1 installed
- Custom breather hole plug
- Harness progress
Page 95:
- New daily
- 86 Nissan hardbody
Page 96:
- NGK blue wires
- NGK plugs
Page 97:
- More harness work
- All hoses hooked up
- NGK wires installed
Page 98:
- No updates
Page 99:
- No updates
Page 100:
- PAGE 100
- Harness almost complete
- Clean solds
- Weather stripping for strut bar
- 15mm wheel spacers
- New Spoon rad cap
- Spoon Gen 1 mirrors paint matched
- Mirrors repaired and reassembled
- Mirrors installed
- BNIB Gen 1 Spoon cam gears
Page 101:
- Harness complete
Page 102:
- Car won't start..
Page 103:
- Gen 1 Spoon gears installed
Page 104:
- New OE 98+ splash guard set
- Order from Honda
- Lots of Castrol 10/30
Page 105:
- Spoon Certification #35373
Page 106:
- Fender liners installed
- Splash guards installed
- Shift linkage cleaned/installed
- New OE dust boot
- New OE bumper hardware
- Running shots
- First test drive
Page 107:
- "No smoking" cig lighter plug
- Interior shot
- New OE mount bolts
- ASC bar/mount w/ Ohiins damper installed
- Rear splash guards installed
- Car out for some sun
- First wash
Page 108:
- Complete bay shot
- Side shot out of the garage
Page 109:
- No updates
- Battery tray shots
Page 110:
- New gas tank lid hardware
- License plate gets Spoond
- Spoon cert. plate installed
Page 111:
- Outside rear shot
- New damper mount hardware
- Spoon blue license plate cover
- Oil change time
- Bay shot
Page 112:
- Throwback shot on Regas
Page 133:
- OEM ITR transmission brace
- Wheel spacers installed
- Height adjusted
- Face shot
Page 114:
- Sunny bay shot
- Truck shot
- Rain shot
- Roof top shoot shots
Page 115:
- Rooftop shoot teaser
- Around town shots
- More rooftop shoot pics
Page 116:
- Sick shot by Anmol (freshabp)
- Rear plate cover tossed on
Page 117:
- Couple throwback shots
- Project work station
- New Denso alternator
Page 118:
- Planning the trip to Cali
- Doin some work at a buddies shop
- New road atlas
- New HT issue
Page 119:
- Update by Hubes "Best Honda" at Year.3
Page 120:
- Update by JDM3 Chronicles preview
- Dyno day
- HP/TQ numbers
- Few shots around town
- Chronicles "T" and VIP for Year.3
- New T bolt clamps for Spoon hoses
- Packed up for trip to SoCal
- Few shots from the drive down South
- Rest stop at Hubes
- Preview at my Sisters place
- Drivin to Year.3
- Few rolling shots by Alex aka (ScarredPavement)
- Year.3 pics
- "Best Honda" awarded at Year.3
- Photo shoot preview
- Some supplies from Honda
Page 121:
- Pullin the transmission to swap rear main seal. All in a nights work
- Pics on the road home
Page 122:
- More shots from the ride home from Socal to WA
- Made it home!
- Pics from "The Chronicles" shots by Joey aka (StickyDilJoe)
- Shot of me and Ms. Holly Lee after being awarded "Best Honda"
- More shots from Year.3 by xhb2lvx
Page 123:
- OEM amber signals swapped on
Page 124:
- Rollin shot from trip to SoCal
- Eli's 74 Mazda
Page 125:
- Shot from The Chronicles "Best of the Rest"
- Truck in the snow
- Integra in the garage
- Checkered Sports race hub
- OEM Honda Accord Euro-R knob
Page 126:
- New hub vs old hub
- GoPro Hero2 cam mounted with suction arm
- First GoPro vid
- Road trip to The Ridge Motorsports park
- My vehicles
Page 127:
- Shot from the trip to The Ridge
Page 128:
- Throwback shots
Page 129:
- Shot from Year.3 by TimScribbles
Page 130:
- Bay shot from Year.3
Page 131:
- Super Street April 12 feature released
- Index shot
- New wheel preview, 16x8 +35 matte black Regas
Page 132:
- New wheels delivered
Page 133:
- Evos fresh out of the box
- More Evos
Page 134:
- No updates
Page 135:
- Disassembled Evo valve stems
- Primed and painted stems
- Dismounted the NT03s
- Dismounted Bridgestones
- Shot of my buddies 340hp vitarra D longblock
- Rims and tires loaded for mounting
- Evo's mounted up
- Evo's ON
Page 136:
- Shot by Joey Lee aka stickydiljoe
- Shots from Super Street
- More shots from The Chronicles
Page 137:
- Nice local shots on a nice day
- Amber vs clear signal lights
- Shot over Oly
Page 138:
- Shot from the bay for The Chronicles header
- Shot from Griots Garage meet in Tacoma
Page 139:
- Checkered Sports hub back from powder coat
- Hub mounted up with the Nardi
Page 140:
- Block plate project started/finished
- Mounted block plate w/ OE hardware
- Wheel spacers back from powder coat
- New to me Craftsman compressor
- Quick shot of the new garage
- New valve cover project
Page 141:
- Shot of the car in my buddies shop
- VC when purchased
- VC after some work done
- VC ready for powder
Page 142:
- Valve cover back from powder coat
- Spoon/TypeOne hardware mocked up on VC
Page 143:
- Nephew Jack drivin my car
- New pacakge
- 350mm Momo Monte Carlo w/ red stiching
- Monte Carlo mounted up
- Random VC shot
Page 144:
- New package
- Mm OEM goods
Page 145:
- New goods from Honda
- Eli's coupe/bay
- Integra getting alignment
- Surprise package from Sammy
Page 146:
- Moroso pan off
- New oil pan installed
- ITR trans brace installed
- New valve cover/hardware
- Old vs new goods
- Valve cover installed
- Close up on the cam cutouts
- Random Spoon shot
Page 147:
- Random shot before the trip to Cali
- Shot from Eibach 12
- Couple shots by Joey from The Chronicles
Page 148:
- No updates
Page 149:
- Shot by Hubes
- Road trip to Eibach
- Circuit Hero plug cover coated/installed
- New trunk board
- Car cleaned up for the next show
- NOS Forum Fest event
Page 150:
-No updates
Page 151:
- Then and Now shots by Stickydiljoe
- Integra FOR SALE thread shot
Page 152:
- Change of heart
- OG Spoon rear tow hook and bandana
Page 153:
- Shot by Joey aka Stikydiljoe
- Spoon rear tow hook installed
Page 154:
- Quick shoot around town
- Random shot from ssbteg
- All cleaned up
Page 155:
- Started a little project- Building a splitter
- Template design
- Supplies
- Template complete
Page 156:
- New overhead garage light
- More progress on the splitter
- Template drawn onto birch wood
- Birch piece cut out
- Rough cut mocked up
Page 157:
- Work bench plans
- Work bench complete
- Garage refreshed
Page 158:
- Tool box organized
- Splitter filler piece started
- Splitter cutout for header
- Grid drawn onto splitter
Page 159:
- Filler piece for splitter finished
- Smoothed out splitter edge/rounded corners
- Applied the first layer of fiber
- Put up a shelf
- More lights in the garage
- Some fun, balsa wood rubberband airplane
Page 160:
- More garage work
- Some tunes
- More fiberglassing
- Fiberglassing "tips"
- Some coffee in the morning
Page 161:
- Sunny day in the NW
- Fiberglassed up the last edge
- Sanded the first layer of fiber
- Suited up
- Close up shots
- All sanded up
- More sanding
- New suit
- New package
- Spoon battely
- Old vs new
- Spoon battely cleaned up and charging
- Man cove/bar/car shrine
- Spoon calage
Page 162:
- Spoon/TYPEONE
- Battery installed
- New package
Page 163:
- More Spoon
- Version 2 plug wire cover
- OG piston top catalog
- Circuit Hero vs Spoon plug cover
- Cover hardware
- Kevlar cover installed
Page 164:
- Another package
- JDM Spoon vanity plate
- Window trim repair/replace
- Quick wash
Page 165:
- JDM Spoon plate tossed on
- Bay shot
- Old VC shots
- New VC plans
- Block off plate project
Page 166:
- Aquaponic garden
- Step project
- Garage cleanup
- M3 style spoiler
- Splitter progress
- Splitter mock up
Page 167:
- New shelf in the garage
- Finger condoms, the fingertip cover
- M3 style spoiler mockup
- Sanding some fiberglass
- Garage sale finds
- Fender cover holder built
- Random car shot
Page 168:
- M3 style spoiler finished up
- Aquaponic system update
- Spoon cluster getting older
- Bondo glass work on the splitter
- New package
Page 169:
- Spoon heat barrier tape
- Extra rays duranuts
- Sunset cruise
- Distance shots
- HIN Tacoma Dome
- All set up with our group
- Random cars I liked from the show
Page 170:
- Bay shot from Nisei in L.A.
- stickydiljoe coverage from Nisei
Page 171:
- RIP Speedracer aka Mike Young
- Car torn down
- Wheels off for refinishing
- Block plate mocked up
- Custom splitter brackets
- Batch of parts to powder coat
- DB door handles
- PDR
- New grommets
- New tires
- New tires mounted up
- Car ready for HIN
- More splitter work
- Final layer of fiber/all resined up
- New hardware
- Weatherstripping added to lip
- Splitter mocked up
- Splitter painted
- Spoon tape installed
- Splitter complete
- Trip to Speedfactory
- Oil change time
- Trip down to Nisei
- Nisei coverage
- "Acura Class Winner" award
- RobsEG6 and I with our trophies
Page 172:
- New package
- Order from HMotorsonline
- Spoon socks and brake calipers
Page 173:
- New package from AutoFair Honda
Page 174:
- What's in the box
- OEM Prelude vtec 4x114 rotors / ITR pads
- More mail
Page 175:
- Couple items from stickydiljoe
- Year.5 VIP entry sticker
- Chronicles "No Rival No Equal" plate frame
- Brake installation prep
- Old setup removed
- Rotor caps painted
- Back plate trimmed
- ITR pad modification
- New caliper mocked up
Page 176:
- No updates
Page 177:
- Out of hibernation part 1
- Spoon caliper install complete
- New Spoon reservoir covers
- Circuit Hero plug cover installed
Page 178:
- Out of hibernation part 2
- Integra all packed up for another trip to SoCal
- View point near Shasta
- The Chronicles Year. V meet
Page 179:
- Out of hibernation part 3
- Stopeed in Seacliff, CA
- Pacific Ocean sunset
- Something you don't see everyday
- Morrow bay beauty
- Southern Oregon sunset
- The Ridge Motorsports park layout shot
Page 180:
- Year.V coverage
- The Chronicles Top Ten Hondas of 2013
Page 181:
- Local spot
- Splitter adjusting
- Fresh paint on the splitter
- Splitter refresh finished and installed
- Nice day in Olympia
- Field trip
- Buddies shop projects
- Old/New valve cover
- Stripping the old paint off the new vc
- New package
- Order from Checkered Sports
- Duracon Black plastic knob
- Checkered vs Spoon
- Rolling shot on I-5 North
____________________________________________________________________________________________________________________________________
Hey guys, been lurking on here the past couple days waiting to start another thread up and I finally gave in.
Just to refresh everyone lets start off back in 07 when I purchased the stock 98 one owner 76k mile mr Integra.
How it sat
The stock un-touched bay...
Couple years and lots of funds later... before the tear down
The bay before the teardown...
Now we are back to where we left off.
While the site was down we got some progress done on the teg. The bay got all sprayed up and I couldn't be happier with how it came out.
Night before:
Day after:
dang!
So stoked to start puttin it all back together
Got a few packages from Rywire over the last week. Real happy with the products. Awesome quality <img name="icon" src="http://xs-s.com/zf/images/smile/emthup.gif" border="0">
Rywire clutch line
(picked up some "illest" decals while I was at it)
Also got the Rywire ls to vtec subharness so I can start rebuilding the harness once again...
Man I'm glad to be back on here. It just wasn't the same without NWP
Will be updating regularly so check back <br /><br />
Modified by skip at 11:52 AM 6/8/2014
Spoon // Desmond // Recaro // ASC Metal Fab // KoyoRad // Innovative // ICB
Super Street Rookie of the Year - 2012
Instagram : @coopakaskip
datwhitaker
OEM or go home.
3158 posts [100%]
We dont park cars, we pahk cahs in New England
3-9-2009
 « Re: **skipunk4's mr dc4 2010 refresh, and so on, and so on** (skipunk4)« » Reply  Edit
Yes! Now I don't have to go the other site to see this build lol
Eg2_Johnny
This fucking guy!
2418 posts [100%]
SGV
11-19-2008
 « Re: **skipunk4's mr dc4 2010 refresh, and so on, and so on** (JDM3)« » Reply  Edit
this is going to be good right here
Pitcrew Motorsports
"Are those real rotas???"
JUAN I MISS AND LOVE YOU.
WTB: 09-12 FIT SPORT STOCK SPOILER.
TRA_Blaze
1242 posts [100%]
New York NY
10-13-2009
 « Re: **skipunk4's mr dc4 2010 refresh, and so on, and so on** (Eg2_Johnny)« » Reply  Edit
glad to see it back up man
2006 GPW AP2 Honda S2000 (Current)
2003 SSM DC5 Acura RSX Type-(S Sold)
1996 CGP DC4 Integra (Sold)
La Familia <img name="icon" src="http://xs-s.com/zf/images/smile/emthup.gif" border="0">
*YoSon Racing*
Dbarnett88
1812 posts [100%]
Seattle WA
1-7-2009
nice!
Mikecm_
When do we eat?
281 posts [100%]
Moreno Valley ca
7-12-2006
 « Re: (Dbarnett88)« » Reply  Edit
Quote, originally posted by Dbarnett88 »
nice!
skip
Spoon me please
4812 posts [100%]
Rainy WA
12-10-2008
 « Re: (Chubz_)« » Reply  Edit
Thanks for the love guys. Lets get this thing goin!
Started off the day with masking off all the holes that go from the wheel well into the bay
I had been slowly cleaning out the wheel wells and finally got em clean enough to paint em
Before: All nasty (don't mind the white its just Comet cleaner)
After: Nice n' fresh, still might lay another coat after its all dried
Picked up an OEM civic harness plug to route the new harness through
Where the harness is goin. Was real about that paint when cutting but it came out clean
Started mocking up a few things in the bay as well.
Couldn't figure out how I was gonna get my battery stay to sit but wanted it in the stock spot. So a buddy chopped up the old OE battery stay and welded the bracket on the bottom.
Came out perfect, looks factory.
All mounted up
Also mocked up the new s2000 clutch master after re threading it to fit. Looks a lot nicer than on the shock tower
Car is comin together slowly but surely. Can't wait to get to drive her again
HLB
591 posts [100%]
Fredericton NB
7-17-2009
 « Re: (skipunk4)« » Reply  Edit
shit man, you're stepping it up
almostjdm
223 posts [100%]
Salem O.R
5-5-2010
lookin good buddy keep it up
Dbarnett88
1812 posts [100%]
Seattle WA
1-7-2009
Inspirational, good progress
HGJ
2363 posts [100%]
Albuquerque NM
8-19-2009
looking good
La Familia...It's more than blood.
I have a rare Asian strain of a very contagious disease called Cars..
big thanks...High Desert Mobile Electronics (hdme)
no0dlez
106 posts [100%]
columbus ohio
12-10-2009
looking good!!
» Return to Build threads
