2002 Acura RSX Type S
120,xxx miles
Weight: 2330 lbs w/o driver prior to roll cage install
Power: 223 whp / 163 wtq
Asking $10,000 OBO
MODS
Engine & Trans
OEM K20A2
Ported RBC Intake Manifold
Donkey Power 850cc Injectors
Deatschwerks DW400 Drop in E85 Fuel Pump Module Assembly from Humble Performance
1320 Header w/ 3" exhaust
OEM Z3 LSD and FD
All new bearings and seals installed during LSD/FD
Trans rebuild and LSD/FD Install completed by a Honda Master Certified Technician at the Honda dealership i work for
Comp Clutch (new never driven on)
Hybrid Racing Gen 1 Shifter
Hybrid Racing Shifter Bushings
Dyno’d in 2021 at 223 whp on E85 at Excessive Autosports
KPRO (v2)
KTUNED Fuel Rail
Hybrid Racing FPR w/ -6AN feed and return
Hybrid Racing AC/PS Delete
Unit2 Oil Pan Baffle
Suspension & Steering
Fortune Auto 510 with 16k / 20k Swift Spring (will have FA info sheets with the vehicle). These are the latest generation from FA and never been driven on or tuned away from what FA does from the factory. The spring rates are a recommended setup from Fortune Auto and designed around a 3” front splitter and PCI rear wing.
PCI Camber/Caster Top Hats (not installed)
I have the CAD files for the strut rod bushings needed to install these with the FA coilovers and will provide them with the sale
PCI Rear Camber Kit
HardRace OEM Lower Ball Joints (not installed)
HardRace Pillowball rear LCA’s (not installed)
DC5 Type R LCA’s
King Motorsports LCA Ball Joint Inserts (I will send the Type R inserts with as well in case a guy wants to switch back to a Type R LBJ)
DC5 Type R Rear brake and trailing arms
Rear Brakes are machined OEM Type R rotors with StopTech pads
StopTech SS brake lines all around
OEM ABS Delete using Civic DX OEM front brake lines and EM1 prop valve
HONED front BBK with Porsche Brembo Calipers
HONED Booster Delete Kit with Brand new OEM Fit Master Cylinder per their recommendations
GLOC R8 Front Brake pads (never used or bedded in)
SHG Motorworks rebuilt steering rack with SHG Delrin Slider (non-lockout)
DV Race/Todd’s Inner tie rods with OEM Outer tie rod ends with 1 season of autocross on them
Volvo EPS conversion, with rack valved properly to run with said EPS conversion
All suspension bolts and nuts have been yellow zinc coated while the suspension rebuild was happening.
All bearings are brand new OEM Honda
Interior & Exterior
Autopower bolt in roll cage
Racequip Drivers Seat (good until 2025)
Racequip Harness - never used (good until 2027)
Momo Mod88 Steering wheel with works bell quick release
17x9 +22mm / 17x8 +35mm Enkei RPF1 with 60% tread left on Kumho V730
Carbon Fiber Hatch
Gutted Interior
4” PCI Side Skirts
The body and paint are in great condition, just need to match some blue panels to the factory Desert Silver Metallic color if it bothers you.
It will come with a brand new Acura hood as well, just un-painted and not installed
Aerocatch Hood pins (not that this is worth anything just quantifying
Here’s an on-car video from the last autocross event I participated in before parking it to do the suspension & brake upgrades along with some maintenance items.
The only thing I had left to get the suspension up to speed is tuning the tie rod geometry and alignment since I installed the Fortune Auto coilovers… I was gearing up to do the HONED front geometry kit before it hit the track but some self reflection made me decide that I need to focus elsewhere for a couple years before trying to go racing.
