Well not much to say but work has been accomplished.
Engine pulled and touch up has began on block
Removed dash assembly to complete AC and Heater delete.
Upon inspection went ahead with removal of dash bar/brace and performed touch up work
All buttoned up for the day and garage “sorted”
End of Weekend One
More cleanup of bay done
Interior 90% assembled
Battery relocation mount, circuit breaker, and power line ran
Installed King Motorsports exhaust and intake manifold studs, BBAlliance PS Delete plate, and some @downstar hardware
Intake Manifold and Throttle Body installed
Also placed a small order for the following :
FatFourCustoms A/C Firewall Plug
Downstar hardware for throttle body and throttle cable
OEM MAP/FIAC/TPS Gaskets, to transfer them over to the new parts
Trying to button up each part COMPLETLEY and not have to go backwards
Fast idle valve. There’s something I truly don’t miss. Just reading that gave me flashbacks of constant idle surge🙃. Im surpised skunk2 retains that.
Sprayed the Brake Booster and Subframe support brace.
Installed Radium M14 to -6 Hard Line adapter fitting, AEM Fuel Rail, InjectorShop O-Ring Kit (highly highly recommend), and Aeromotive Fuel Pressure Gauge
Want to spray my subframe next? Its only a short drive
Taking longer than planned due to brother in law being an hour away with car at his place.
Doing some more prep on the bay to finish, but during this winter storm and in-climate weather can’t paint properly.
Still have a good amount of stuff to order as well, but rather “perfect” what I can before I get it back on the road.
I know what that’s like, my car is about half an hour away at my buddy’s place if traffic is light so it’s not easy to really keep the progress going all the time.
And yeah, don’t rush. Specially with paint because you will regret it.
Had a good friend come correct the timing and balance shaft belts, new crank pulley and bolt installed, got alternator mounted with a/c delete belt, new cap and rotor, and installed water pipe with o-rings
Long delay but much progress.
Switched jobs back into the auto industry so less phone time.
Engine is all together just waiting to install NEW valve cover until motor is in to prevent damage.
Bay is fully prepped for touchup work. Hybrid Shift Cables arrived and ready to route in as well.
So close i can smell the leaking oil.
Also ordered a Planted Tech seat bracket for driver side, now to decide on seat selection for my bum.
Is it truly project car if it doesn’t leak oil?
Bay is fully sprayed with DupliColor Milano Red and 2K Clear Aerosol. Not bad at all, yet not perfect.
Got my HybridRacing RSX cables routed and pushed through the cabin.
Placed order for all new Honda motor mount bolts today.
Want to mount my shifter box and cables next? I’m being lazy
Hahaha lets boogie. Name the date
Oooo also got the new KStuned swivel water neck. That piece is freaking work of art!!!
Be here Friday or Thursday
KStuned water neck installed
