My boring ej 4dr
so back in october of 2021 i decided i needed another honda …
talked to my homie and he said he knew of a 4dr that was for sale so i hopped on it .
photos i got of the car from him . good decent start and something i can mess with from time to time . when i got the car it was on some random coilovers , integra front knuckles . had ek4 mirrors , sir rep front and rear bumpers . del sol front seats and some really shitty 6 puck clutch that went
drove it around like this for a while then i started having trouble starting the car after it was warmed up , traced it down to a faulty head gasket . coolant would seep into the cyl and cause it to not want to start after driving for a little while . so while i was in there i replaced the gasket along with the intake manifold and all the hoses i got direct from honda . didnt really take photos of the process
after that fix ended up driving the car full time and really noticed all the blown out bushings and sloppiness of the car so i replaced the front bearings , hubs , ball joints , inner and outer tie rods , pads , rotors , control arms and sway bar bushings . eventually i replaced the sway bar with a blox 26mm but im horrible with taking photo’s !!
not too long after that i started grabbing parts to rear disc the car and overhaul the rear suspension as well . put in a brace , sway bar , lower control arms , swapped the spindles , new hubs , calipers , parking cables and brakes .
after all the the suspension was sorted i decided to change up the interior since that’s what you really see constantly and gives you the most feedback . wasn’t a fan of the del sol seats so those got replaced for a set of si seats . after that i changed out the full climate for a 99-00 and the center console for a domani and added a built by hutch cup holder to it . also added a set of oem black floor mats in there . this is my daily so its never too clean but its comfortable
IMG_4436
somewhere in all that time i changed out my intake for a itr arm and ct ice box , fixed my ac compressor and have been gathering parts to slap a b18 into it for a full oem swap and eventually BAR it .
ill try and update this as i go along , i forget a lot and suck at photos so sorry in advance
Got a b series trans for a decent price so I started to tear it down . Just waiting for parts to arrive so I can rebuild it . Just a plain LS
Changed the wheels a while back and took this photo when it randomly snowed here in Southern California . Only “recent” photo I really have of the car
