Please post all your K Swap builds here. Give a little brief description of what your setup is about.
Here’s my 96 Civic DX with 02 K20A2. Matching transmission and ECU. This swap is meant for daily driving. Do not plan on making crazy power. Currently in the process of getting it BARd ( California )
I rocked around with this set up until Spring of this year when I did a 05 TSX (K24A2) swap. Besides the cheap cost on it ,that I couldn’t pass up on, I wanted a little more HP/TRQ to scoot and move.
Then there’s this 04 RSX K20A3 that I have. been kicking around the idea of a VTEC Killer set-up for it. I have the parts for it pls/minus, just haven’t pulled the trigger because I’m working on another K swap for the hatchback at the moment.
93 Dx hatchback. 07 k24a2 with supertech 95lb springs and IPS K2 cams, rbc w/ 70mm tb and r crew header. 3in exhaust, 1000cc injectors pump e85. Z1 gearbox in a a2 case w/ z3 lsd, CM twin disc. Made 266/208 all motor 373/294 on nitrous. #seanbuilt#derftuned
